Learn MoreTrucker Path for Fleets + J. J. Keller
J. J. Keller ELD and Truck-Safe GPS
- Connect with DOT/MC, Email, Username and Password
- Dispatch truck-safe routes to the driver app
- Four
- Fields the J. J. Keller connect box asks for
- Zero
- Changes to your J. J. Keller setup
- 7 days
Before you start
The Four Fields J. J. Keller Asks For
The J. J. Keller entry asks for four things, not a single sign-in. Two of them are simply your carrier number and your email; the rest come from the account you already hold.
How it connects
How the J. J. Keller Connection Works
- 01Connect
Connect the Trucks That Need It
Start your Trucker Path for Fleets trial, open Connect Account in Settings and choose J. J. Keller. Enter the DOT/MC, Email, Username and Password listed above. Drivers and their hours of service come across on their own. Nothing is installed, and your J. J. Keller ELDs is not touched.
- 02Plan
Plan Around Real Hours
Routes are built from your truck profiles and each driver’s remaining hours, read live out of Encompass rather than re-keyed from a report.
- 03Dispatch
Dispatch to the Driver App
Send the route from the dashboard to the driver app in one tap. Only the trucks you connected are affected; everything else on the account carries on untouched.
What Encompass covers
Compliance Is the Whole Point of Encompass
J. J. Keller describes Encompass as a cloud-based system covering driver qualification, hours of service, hiring, and alcohol and drug program management, and says it has served the transportation industry for over 70 years with more than 500,000 customers. None of that work moves when you connect.
Driver qualification files stay in Encompass
Hiring, qualification, drug and alcohol programs are Encompass’s job and are untouched by the connection.
Hours of service stay the record
Encompass remains where your logs live. Trucker Path reads the clocks and never writes back.
What gets added is the road
A route built on the rig, with toll cost visible before dispatch and turn-by-turn in the driver’s own app.
SyncedRelated pages
Other Ways Fleets Connect
- All ELD integrationsEvery ELD on the list, and what each one asks for.
LB TechnologyDirect
One Step GPSDirect
Product names and logos are trademarks of their respective owners, used here to describe compatibility.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my J. J. Keller subscription?
No. It is an add-on, not a replacement. Encompass stays your system of record for hours of service, compliance and driver scoring. Trucker Path adds truck-safe routing and dispatch beside it.
Is the J. J. Keller integration free?
Connecting J. J. Keller costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
Does this touch our driver qualification files?
No. The connection reads drivers, vehicles and hours of service only. Everything else in Encompass is unaffected.
We run Encompass with Geotab hardware. Which entry do we use?
Pick the entry matching the sign-in you hold for the account that holds the logs. If you are unsure, our team will confirm before you start.
Does this affect our drug and alcohol program records?
No. Everything Encompass manages beyond hours of service is untouched. The connection is read-only.
We use J. J. Keller for consulting as well as ELDs.
That relationship is unaffected. The connection reads the account that holds your logs.
Who needs to be involved to connect?
Anyone holding a working J. J. Keller sign-in and your carrier number. No key to request, and no approval to wait on.
Still have questions? Our team will help you get connected.navpro@truckerpath.com
Your ELD stays
J. J. Keller Stays. Your Routing Gets Fixed.
Start a 7-day free trial and connect only the trucks that need truck-safe routing, leaving your J. J. Keller ELDs to run everything else on the account.
Connect J. J. Keller Account
