Learn MoreTrucker Path for Fleets + GPSTab
GPSTab ELD and Truck-Safe GPS
- Connect with DOT/MC, Email and API Key
- Dispatch truck-safe routes to the driver app
- Three
- Fields the GPSTab connect box asks for
- Zero
- Changes to your GPSTab setup
- 7 days
Before you start
The Three Fields GPSTab Asks For
The GPSTab entry asks for three things, not a single sign-in. Two of them are simply your carrier number and your email; the rest come from the account you already hold.
Who GPSTab is for
Built for Fleets That Set Up Their Own Tools
GPSTab describes itself as built by truckers for truckers, says its ELD installs in under a minute and pairs with a mobile device, and sells without a contract. Fleets running it usually do their own setup, and this connection is the same shape: a form, once, in Settings.
Setup stays in your hands
The connect form takes your carrier number, your email and a key generated inside GPSTab. No call, no scheduling.
GPSTab stays the record
Logs, hours of service and compliance reporting stay GPSTab’s. Trucker Path reads and never writes back.
What gets added is the route
Height, weight, length and axle count per truck, with toll cost visible before dispatch.
SyncedHow it connects
How the GPSTab Connection Works
- 01Connect
Fill the Form Once
Start your Trucker Path for Fleets trial, open Connect Account in Settings and choose GPSTab. Enter the DOT/MC, Email and API Key listed above. Drivers and their hours of service come across on their own. Nothing is installed, and your GPSTab device is not touched.
- 02Plan
Plan Around Real Hours
Routes are built from your truck profiles and each driver’s remaining hours, read live out of GPSTab rather than re-keyed from a report.
- 03Dispatch
Dispatch to the Driver App
Send the route from the dashboard to the driver app in one tap, with no setup call to schedule and nothing to install in the truck.
Related pages
Other Ways Fleets Connect
- All ELD integrationsEvery ELD on the list, and what each one asks for.
- ISAAC InstrumentsDirect
LB TechnologyDirect
Product names and logos are trademarks of their respective owners, used here to describe compatibility.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my GPSTab subscription?
No. It is an add-on, not a replacement. GPSTab stays your system of record for hours of service, compliance and driver scoring. Trucker Path adds truck-safe routing and dispatch beside it.
Is the GPSTab integration free?
Connecting GPSTab costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
Who needs to be involved to connect?
Someone who can generate an API key inside GPSTab. Everything else is your carrier number and email.
Does this change the GPSTab app drivers use?
No. Duty status stays in GPSTab. The route arrives in the Trucker Path app.
Do we need GPSTab support involved?
Only if you cannot find the API key in your own account. Nothing has to be requested from GPSTab first.
Does this replace the GPSTab driver app?
No. Duty status stays in GPSTab. The route opens in the Trucker Path app.
Someone who can generate an API key inside GPSTab. Keys are usually restricted to administrators, so if that is not you, that is the one person to ask.
Still have questions? Our team will help you get connected.navpro@truckerpath.com
Your ELD stays
GPSTab Stays. Your Routing Gets Fixed.
Start a 7-day free trial and connect GPSTab from Settings. Connecting costs nothing extra, and your GPSTab device is untouched.
Connect GPSTab Account
