Learn MoreTrucker Path for Fleets + PeopleNet
PeopleNet ELD and Truck-Safe GPS
- Connect with DOT/MC, Email, Username and Password
- Dispatch truck-safe routes to the driver app
- Four
- Fields the PeopleNet connect box asks for
- Zero
- Changes to your PeopleNet setup
- 7 days
Where PeopleNet sits now
PeopleNet Is Trimble
PeopleNet is now part of Trimble Transportation, and the name still appears on the hardware: Trimble documents its ELD as certified for Canada when used with either the PeopleNet Mobile Gateway (PMG) or the PeopleNet Connected Gateway (PCG). Paperwork or drivers still saying PeopleNet mean the same system.
The gateway keeps its name
Trimble names the PMG and PCG gateways directly in its own certification wording, so the hardware in the truck is the hardware the connection reads.
Compliance stays in Trimble
Trimble describes Driver ELD as compliant with the US and Canadian mandates and built on Android. That work does not move.
What gets added is the route
Truck-safe routing built on each truck’s height, weight, length and axle count, with toll cost visible before the trip is dispatched.
SyncedBefore you start
The Four Fields PeopleNet Asks For
The PeopleNet entry asks for four things, not a single sign-in. Two of them are simply your carrier number and your email; the rest come from the account you already hold.
How it connects
How the PeopleNet Connection Works
- 01Connect
Fill the Form Once
Start your Trucker Path for Fleets trial, open Connect Account in Settings and choose PeopleNet. Enter the DOT/MC, Email, Username and Password listed above. Drivers and their hours of service come across on their own. Nothing is installed, and the PeopleNet gateway is not touched.
- 02Plan
Plan Around Real Hours
Routes are built from your truck profiles and each driver’s remaining hours, read live out of Trimble Driver ELD rather than re-keyed from a report.
- 03Dispatch
Dispatch to the Driver App
Send the route from the dashboard to the driver app in one tap. The name on the contract does not change what the driver sees: turn-by-turn directions, on the phone they already carry.
Related pages
Other Ways Fleets Connect
Product names and logos are trademarks of their respective owners, used here to describe compatibility.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my PeopleNet subscription?
No. It is an add-on, not a replacement. Trimble Driver ELD stays your system of record for hours of service, compliance and driver scoring. Trucker Path adds truck-safe routing and dispatch beside it.
Is the PeopleNet integration free?
Connecting PeopleNet costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
Is PeopleNet the same as Trimble?
Yes. PeopleNet is now part of Trimble Transportation. Trimble still names the PeopleNet Mobile Gateway and PeopleNet Connected Gateway in its own ELD certification wording, so a fleet that bought PeopleNet is running what Trimble now sells.
Our logs say Trimble but our contract says PeopleNet. Which do I pick?
Pick PeopleNet in the connect list. It is the same account either way.
We still call it PeopleNet internally. Will support know what we mean?
Yes. PeopleNet is the entry in the connect list, and it is the same integration whether your paperwork says PeopleNet or Trimble.
Does this work with both the PMG and the PCG gateway?
The connection reads your account rather than a specific gateway, so a fleet running a mix of PeopleNet Mobile Gateway and PeopleNet Connected Gateway trucks connects once.
Who needs to be involved to connect?
Anyone holding a working PeopleNet sign-in and your carrier number. No key to request, and no approval to wait on.
Still have questions? Our team will help you get connected.navpro@truckerpath.com
Your ELD stays
PeopleNet Stays. Your Routing Gets Fixed.
Start a 7-day free trial and connect PeopleNet from Settings. Whichever name the contract carries, the PeopleNet gateway and the logs it produces do not move.
Connect PeopleNet Account
