Learn MoreTrucker Path for Fleets + Telogis
Telogis ELD and Truck-Safe GPS
- Connect with DOT/MC, Email, Username and Password
- Dispatch truck-safe routes to the driver app
- Four
- Fields the Telogis connect box asks for
- Zero
- Changes to your Telogis setup
- 7 days
Where Telogis sits now
Telogis Is Verizon Connect
Verizon Connect states it plainly on its own site: "Telogis has become Verizon Connect." The platform description that follows is a fleet management platform for monitoring a fleet in near-real time, optimizing routes and helping reduce fuel consumption. A fleet that signed with Telogis is on Verizon Connect today.
The account carried over
Telogis customers were moved to Verizon Connect, so the sign-in you already use is the one the connection reads.
Compliance stays where it is
Verizon Connect describes its platform as simplifying and automating compliance work, including driving hours and inspections. None of that moves.
What gets added is the road
A route built on the rig rather than a car map, and toll cost visible before dispatch.
SyncedBefore you start
The Four Fields Telogis Asks For
The Telogis entry asks for four things, not a single sign-in. Two of them are simply your carrier number and your email; the rest come from the account you already hold.
How it connects
How the Telogis Connection Works
- 01Connect
Fill the Form Once
Start your Trucker Path for Fleets trial, open Connect Account in Settings and choose Telogis. Enter the DOT/MC, Email, Username and Password listed above. Drivers and their hours of service come across on their own. Nothing is installed, and your existing hardware is not touched.
- 02Plan
Plan Around Real Hours
Routes are built from your truck profiles and each driver’s remaining hours, read live out of Verizon Connect rather than re-keyed from a report.
- 03Dispatch
Dispatch to the Driver App
Send the route from the dashboard to the driver app in one tap. The name on the contract does not change what the driver sees: turn-by-turn directions, on the phone they already carry.
Related pages
Other Ways Fleets Connect
- All ELD integrationsEvery ELD on the list, and what each one asks for.
- Verizon ConnectDirect
Verizon Connect RevealDirect
Product names and logos are trademarks of their respective owners, used here to describe compatibility.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my Telogis subscription?
No. It is an add-on, not a replacement. Verizon Connect stays your system of record for hours of service, compliance and driver scoring. Trucker Path adds truck-safe routing and dispatch beside it.
Is the Telogis integration free?
Connecting Telogis costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
Is Telogis still a separate product?
No. Verizon Connect states on its own site that "Telogis has become Verizon Connect." Your account and data moved with the name.
Should I connect Telogis or Verizon?
Use the entry that matches the sign-in you actually hold. Both are in the list, and the connect panel asks for the same four details either way.
Our logins still go to a Telogis address. Is that a problem?
No. Use the sign-in you actually hold. Verizon Connect moved the Telogis product under its own name and the account carried over.
We were told Telogis is being retired. Should we wait?
You do not need to. The connection reads the account you hold today, and it takes four details to set up.
Who needs to be involved to connect?
Anyone holding a working Telogis sign-in and your carrier number. No key to request, and no approval to wait on.
Still have questions? Our team will help you get connected.navpro@truckerpath.com
Your ELD stays
Telogis Stays. Your Routing Gets Fixed.
Start a 7-day free trial and connect Telogis from Settings. Whichever name the contract carries, your existing hardware and the logs it produces do not move.
Connect Telogis Account
