Learn MoreTrucker Path for Fleets + Motive
Motive ELD and Truck-Safe GPS
- Sync Motive assets and drivers for compliant routing
- Dispatch routes directly to Trucker Path GPS
- 7 days
- Zero
- Changes to your Motive setup
- Minutes
- To connect Motive in Settings
Alongside Motive
What Trucker Path for Fleets Adds
Motive was called KeepTruckin until 2022, so paperwork or drivers still saying KeepTruckin mean the same company. Your dispatchers work in the Motive Fleet Dashboard. Your ELD stays the system of record for hours of service logs, compliance and driver scoring. Trucker Path adds routing and dispatch without changing your setup.
Truck-safe routing
Avoid low bridges, weight limits and truck-restricted streets—not a generic car map.
Live HOS clocks
See live HOS clocks in Trucker Path navigation—no app switching.
Toll costs before you dispatch
See toll costs before you dispatch, and take the cheaper route.
How it connects
How the Motive Connection Works
- 01Connect
Connect Motive, Two Ways
Start your Trucker Path for Fleets trial, open Settings and pick whichever suits how your fleet runs: sign in with your Motive account and approve the request, or paste in an API token. The two are compared below.
- 02Plan
Plan Around Real Hours
Routes are built from your truck profiles and each driver's live hours of service from Motive, not from a generic car map.
- 03Dispatch
Dispatch to the Driver App
Send the route from the dashboard to the driver app in one tap for turn-by-turn directions. Hours of service status and live position stay visible in both systems.
Two ways in
Sign In, or Paste a Token
The Motive connect panel offers both, and neither gives Trucker Path more access than the other. Both read drivers, vehicles and hours of service, and neither writes anything back to Motive. What differs is who does the setup.
Where Motive sits
What Motive Covers, and What Sits Beside It
Motive describes itself as an all-in-one fleet management and driver safety platform — "one platform to help improve the Safety, Productivity and Profitability of your operations". Its own product list runs from ELD compliance and GPS tracking to AI dashcams, maintenance, spend management and driver coaching. None of that changes when you connect Trucker Path.
Compliance and safety stay in Motive
Hours of service logs, the AI dashcam, driver coaching and accident management are Motive's, and they carry on exactly as they do now. Trucker Path reads drivers, vehicles and hours of service; it does not write anything back.
What gets added is the route
Truck-safe routing built on each truck's height, weight, length and axle count, with toll cost visible before the trip goes out, and the route landing in the Trucker Path app the driver already has on their phone.
Known as KeepTruckin until the rename
Motive still carries "Formerly KeepTruckin" on its own connect panel, so a fleet that set the account up years ago may know it under the old name. The connection is the same either way.
Related pages
Other Ways Fleets Connect
- All ELD integrationsEvery ELD on the list, and what each one asks for.
GeotabDirect
Blue Ink TechDirect
Product names and logos are trademarks of their respective owners, used here to describe compatibility.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my Motive subscription?
No. It is an add-on, not a replacement — you keep Motive for HOS/ELD compliance and driver behavior scoring, and add truck-safe routing and fuel network discounts on top.
Is the Motive integration free?
Connecting Motive costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
How do I connect my Motive account?
Two ways, and the connect panel offers both. Most fleets sign in with their Motive account and approve the request — nothing to request, nothing to wait for. The other way is an API token: your Motive administrator creates it in the Motive Dashboard under the admin icon, then Developers, then Request API Key, and Motive issues one key per organization. Either way you start a Trucker Path for Fleets trial, connect from Settings, and your drivers and their hours of service status sync over. Trucker Path for Fleets reads driver, vehicle and hours of service data, and does not write back to Motive.
Should I use the login or the token?
Signing in is quicker and there is nothing to request. A token suits fleets that keep integrations under an administrator, or where the person setting this up is not the person holding the Motive login. Both give Trucker Path the same read access to drivers, vehicles and hours of service.
Where do I get a Motive API token?
From your own Motive Dashboard, not from us: the admin icon, then Developers, then Request API Key. Motive issues one key per organization and documents the steps in their help center, which the connect panel links to directly.
Where do I see my HOS clocks after connecting?
Right inside Trucker Path's navigation screen — drivers don't need to switch apps to check remaining hours.
Do I need to change anything in Motive?
No. Your ELD hardware, HOS logs, and driver settings stay exactly as they are.
Still have questions? Our team will help you get connected.navpro@truckerpath.com
Your ELD stays
Your ELD Stays. Your Routing Gets Fixed.
Start a 7-day free trial and connect Motive from Settings. Nothing changes in your Motive setup.
Connect Motive Account
