Learn MoreTrucker Path for Fleets + Geotab
Geotab ELD and Truck-Safe GPS
- Connect with your MyGeotab database, server and sign-in
- Dispatch truck-safe routes to the driver app
- Four
- Fields the Geotab connect box asks for
- Zero
- Changes to your Geotab setup
- 7 days
Before you start
The Four Fields Geotab Asks For
Geotab does not identify an account by email alone, so the connect box asks for four things rather than one sign-in. Geotab documents its own address structure as https://<serverName>/<databaseName>/#<page>, which means two of the four are already on screen whenever an administrator is signed in to MyGeotab.
How it connects
How the Geotab Connection Works
- 01Connect
Enter the Four Fields Once
Start your Trucker Path for Fleets trial, open Connect Account in Settings and choose Geotab. Enter the database, server, email and password from the table above. Drivers and their hours of service come across on their own, with no CSV uploads.
- 02Plan
Plan Around Real Hours
Routes are built from your truck profiles and each driver's live hours of service from Geotab, not from a generic car map.
- 03Dispatch
Dispatch to the Driver App
Send the route from the dashboard to the driver app in one tap for turn-by-turn directions. Hours of service and live position stay visible in both systems.
Alongside Geotab
What Trucker Path for Fleets Adds
The GO device in your diagnostic port sends engine and position data to MyGeotab, drivers set duty status in Geotab Drive, and MyGeotab puts the two together into the log you read. None of that moves. What is missing from that picture is the road itself — whether the route you just dispatched fits the truck running it.
A route built on the rig, not the car map
Height, weight, length and axle count per truck, so a low bridge or a truck-restricted street is handled before the driver reaches it.
The same clocks Geotab is already recording
Drivers read remaining hours inside Trucker Path navigation. Dispatch plans against one set of numbers, not two.
Toll cost visible before you dispatch
See what a route will cost in tolls while you are still choosing it, and send the cheaper one.
SyncedRelated pages
Other Ways Fleets Connect
- Geotab from AT&TThe AT&T-branded Geotab is its own entry in the list.
- All ELD integrationsEvery ELD on the list, and what each one asks for.
SamsaraDirect
MotiveDirect
Blue Ink TechDirect
VerizonDirect
Product names and logos are trademarks of their respective owners, used here to describe compatibility.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my Geotab subscription?
No. It is an add-on, not a replacement. Geotab stays your system of record for hours of service, compliance and driver scoring. Trucker Path adds truck-safe routing and dispatch beside it.
What do the database and server fields want?
They identify which MyGeotab account to read. Geotab documents the server as "the name of the server the database is on", giving my.geotab.com as its example, and the database as "the name of the database", which is "typically the company name used during registration".
Where do I find my Geotab database name?
Geotab documents its address structure as https://<serverName>/<databaseName>/#<page>, so both values sit in the MyGeotab address while an administrator is signed in. Geotab also notes that spaces in the name "are replaced with underscore characters (_)", so a company registered as Acme Trucking becomes Acme_Trucking.
Which MyGeotab account should I use?
The connect box takes the email and password of a MyGeotab user on the database you want to connect. If you are not sure which account that should be, your Geotab administrator will know.
My Geotab came through AT&T. Is this the same integration?
No. Geotab sells direct and through partners who, in Geotab's own words, may "whitelabel, resell, or take advantage of Geotab's global Reseller network". The connect list carries the AT&T-branded Geotab as its own entry, separate from the native one. Pick the entry that matches how your Geotab was sold to you.
Is the Geotab integration free?
Connecting Geotab costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
Where do I see hours of service after connecting?
Inside the Trucker Path navigation screen. Drivers do not switch apps to check remaining hours.
Do I need to change anything in Geotab?
No. Your GO devices, logs and driver settings stay exactly as they are.
Still have questions? Our team will help you get connected.navpro@truckerpath.com
Your ELD stays
Your ELD Stays. Your Routing Gets Fixed.
Start a 7-day free trial and connect Geotab from Settings. Nothing changes in your Geotab setup.
Connect Geotab Account
