Learn MoreTrucker Path for Fleets + Verizon Connect
Verizon Connect ELD and Truck-Safe GPS
- Connect with Username and Password
- Dispatch truck-safe routes to the driver app
- Two
- Fields the Verizon Connect connect box asks for
- Zero
- Changes to your Verizon Connect setup
- 7 days
Before you start
The Two Fields Verizon Connect Asks For
The Verizon Connect entry asks for two things, and both come from the account you already hold.
How the connection works
Self-Serve, Not a Marketplace Request
The Verizon Connect entry is a straightforward credentials form: your existing username and password, entered once in Settings. It is not a partner approval or a marketplace request, and the developer-portal process Verizon documents for raw API access does not apply to this flow.
No approval to wait on
Two fields, your existing Verizon Connect sign-in, and the drivers and hours come across.
Verizon Connect stays the record
GPS tracking, maintenance alerts and compliance reporting stay where they are. The connection reads and never writes back.
What gets added is the route
Truck-safe routing built on the rig, with toll cost visible before dispatch.
SyncedHow it connects
How the Verizon Connect Connection Works
- 01Connect
Fill the Form Once
Start your Trucker Path for Fleets trial, open Connect Account in Settings and choose Verizon Connect. Enter the Username and Password listed above. Drivers and their hours of service come across on their own. Nothing is installed, and your existing hardware is not touched.
- 02Plan
Plan Around Real Hours
Routes are built from your truck profiles and each driver’s remaining hours, read live out of Verizon Connect rather than re-keyed from a report.
- 03Dispatch
Dispatch to the Driver App
Send the route from the dashboard to the driver app in one tap, with no setup call to schedule and nothing to install in the truck.
Related pages
Other Ways Fleets Connect
- All ELD integrationsEvery ELD on the list, and what each one asks for.
TelogisDirect
Verizon Connect RevealDirect
Product names and logos are trademarks of their respective owners, used here to describe compatibility.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my Verizon Connect subscription?
No. It is an add-on, not a replacement. Verizon Connect stays your system of record for hours of service, compliance and driver scoring. Trucker Path adds truck-safe routing and dispatch beside it.
Is the Verizon Connect integration free?
Connecting Verizon Connect costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
Do we need Verizon to approve the integration first?
No. The connect panel takes your existing Verizon Connect username and password. The developer-portal process Verizon documents covers raw API access, which is a different thing.
We were on Telogis. Which entry do we use?
Verizon Connect states on its own site that "Telogis has become Verizon Connect". Both appear in the list; use the one your sign-in belongs to.
We were told we needed developer portal access.
That applies to raw API access. The connect panel here takes your existing Verizon Connect username and password.
Does this work with Verizon Connect Reveal?
Reveal appears separately in the list. Use the entry that matches the product your sign-in belongs to, and ask us if you are not sure.
Who needs to be involved to connect?
Anyone holding a working Verizon Connect sign-in and your carrier number. No key to request, and no approval to wait on.
Still have questions? Our team will help you get connected.navpro@truckerpath.com
Your ELD stays
Verizon Connect Stays. Your Routing Gets Fixed.
Start a 7-day free trial and connect Verizon Connect from Settings. Connecting costs nothing extra, and your existing hardware is untouched.
Connect Verizon Connect Account
