Learn MoreTrucker Path for Fleets + Samsara
Samsara ELD and Truck Safe GPS
- Sync Samsara assets and drivers for compliant routing
- Dispatch routes directly to Trucker Path GPS
- 7 days
- Zero
- Changes to your Samsara setup
- Minutes
- To authorize Samsara in Settings
Mixed fleets
Connect Only the Trucks That Need It
Samsara lists construction, food and beverage, passenger transit, field services and the public sector among the operations it runs. Most fleets on it are not only trucks — and only the trucks need routing built on height and weight.
Vans and equipment stay where they are
The assets that do not need truck-safe routing keep running in Samsara alone. Nothing about them changes.
The tractor-trailers get a route built on the rig
Height, weight, length and axle count per truck, so a bridge that clears a service van but not a 13'6" trailer is handled before the driver reaches it.
One hours-of-service source, two screens
The clocks a dispatcher plans against are the same ones Samsara is recording. Nobody is reading two numbers and guessing which is right.
SyncedHow it connects
How the Samsara Connection Works
- 01Authorize
Authorize Samsara
Start your Trucker Path for Fleets trial, then authorize Samsara in Settings. Your drivers and their hours of service status sync over automatically, with no CSV uploads.
- 02Choose
Pick Which Trucks Connect
A mixed fleet does not have to bring everything across. Connect the tractor-trailers that need routing on height and weight, and leave the vans, trailers and equipment running in Samsara alone.
- 03Dispatch
Plan Against the Clock Samsara Is Already Keeping
The hours a dispatcher plans against are read live from Samsara, so there is one source and not two numbers to reconcile. The route then goes from the dashboard to the driver app in one tap, and position and hours-of-service status stay visible in both systems. Samsara stays the record; Trucker Path never writes back to it.
What Samsara publishes about itself
Living alongside what you already run
Nothing in Samsara Changes When You Connect
- Hours of service logs, edits and the compliance record stay in Samsara. Trucker Path reads them and never writes back.
- Cameras, coaching and driver safety scoring carry on exactly as they do now.
- Samsara publishes 350+ integrations. A read-only connection does not disturb any of them.
- What gets added is the route: truck-safe on each truck's height, weight, length and axle count, with toll visible before dispatch.
- The route lands in the Trucker Path app your drivers already have on their phones.
FAQ
Frequently Asked Questions
Does connecting Trucker Path for Fleets replace my Samsara subscription?
No. It is an add-on, not a replacement. You keep Samsara for hours of service, compliance and driver behavior scoring, and add truck-safe routing and fuel network savings on top.
Is the Samsara integration free?
Connecting Samsara costs nothing extra. Trucker Path for Fleets itself is a paid subscription and starts with a 7-day free trial, which needs a credit card to begin.
How do I connect my Samsara account?
Two ways. Most fleets authorize Samsara directly: sign in with your existing Samsara credentials, approve the request, and drivers and vehicles start syncing. Fleets that keep integrations locked down can connect with a read-only Samsara API token created by their Samsara administrator.
Where do I get a Samsara API token?
Your Samsara administrator creates it in the Samsara dashboard. Samsara documents the steps in its developer documentation at developers.samsara.com.
Where do I see hours of service after connecting?
Inside the Trucker Path navigation screen. Drivers do not switch apps to check remaining hours.
Do I need to change anything in Samsara?
No. Your hardware, logs and driver settings stay exactly as they are.
Still have questions?navpro@truckerpath.com
Related pages
Other Ways Fleets Connect
- All ELD integrationsEvery platform Trucker Path for Fleets connects to, and what each connection takes.
MotiveSign in with your Motive account, or connect with an API token.
GeotabConnect with your existing database, email, password and server.- Fleets of 2 to 25 trucksDispatch and truck-safe routing for a fleet running without a back office.
- TMS integrationSend stops from the system that already holds the load to the driver's app.
VerizonConnect a Verizon Connect account from the same Settings panel.
Your ELD stays
Your ELD Stays. Your Routing Gets Fixed.
Start a 7-day free trial and authorize Samsara from Settings. Nothing changes in your Samsara setup.
Connect Samsara Account
